Home > Message Board > Car Audio > Amplifiers > Archive through June 24, 2005 > HIGH POWER AMPLIFIER SUGGESTION
Author Thread: HIGH POWER AMPLIFIER SUGGESTION
Username: Riebread77
I recently bought an Eclipse SW9152 dual 4 ohm voice coil. I'm looking to spend no more than $600-$650 on an amplifier. I was interested in the MA hk-4000d...what do you guys think? Any other suggestions?
Username: Thrushdtd
New York
Post Number: 120
why do you need 4000rms from the MA hk-4000d. your sub is only 750rms i think.
The subwoofer is a complete monster...44 mm xmax...5000 watts max and 3000 continous power handling...so I need a good amount of power.
Username: Thrushdtd
New York
Post Number: 124
r u sure you gave the right item number?
Username: Subfanatic
Walton, Ky
Post Number: 4322
yea that item number is for a eclipse ti, the ti pro has a pro at the end of it lol
Username: Thrushdtd
New York
Post Number: 125
ahhh
Post Number: 9
haha its all good...any suggestions though??? haha
Username: Mikechec9
Chicago/atlanta
Post Number: 208
yeah, the pro is a dvc 1ohm. the standard 9152 is 4ohm dvc.
its still a monster though.
Username: Mikechec9
Chicago/atlanta
Post Number: 209
the mmats 1400.1 or 1400.2 is a good amp to push it with.
Post Number: 11
I liked that amp...however the input sensitivity is a bit low...2.5V RMS...I have an Audiocontrol Matrix line driver...9.5V RMS...I'm looking for something that can handle at least 8v.
Home > Message Board > Car Audio > Amplifiers > Archive through June 24, 2005 > HIGH POWER AMPLIFIER SUGGESTION [ « Previous ] [ Next » ]
