Home > Message Board > Car Audio > Amplifiers > Archive through June 24, 2005 > Is PPI A600.2 enough for a set of com...
Author Thread: Is PPI A600.2 enough for a set of comps and subwoofer?
Naras
Hi,
I wanted to buy a good SQ amp which shiuld be good for CDT HD Comps and an 12 inch IDQ.
Will PPI A600 is good to run both.
Thanks
Username: Carguy
Post Number: 3320
PPI A600.2 is one of the best amps produced in the past. It will more than power your CDT comps, as well as your 12" IDQ. As long as you obey the minimum ohm requirement on the amp, you should be fine. Also, if you're planning to power all of them with one amp, then you will need non polarized capacitors for the comps, and crossover coil for the sub.
Naras
Issac thanks for the reply.
This how I am planning to use PPI A600.2 :
1st channal to power CDT's which are 4 ohms speaker(speakers are going to be wired in Parallel for 2 ohm load)
2nd channel for IDQ dual 4-ohm voice coils (coils wired in parallel for 2 ohm load)
Will this work fine?
Thanks
Username: Winn
Santa Ana, California
US
This is really helpful,
Does it also work for my comp MB Quart PCE213 and Sub 1 JL 10W3v2 D4 ??
Does both of comp and sub need to be at the same ohm ??
And in this case, I need Y connector for MB quart comp ???
Thanks
Username: Carguy
Post Number: 3346
Naras, PPI is a 2 channel amp, so you can't divide it up. To power both the component and sub, you will need to operate the amp in "tri" mode. What that means is, you connect channels 1 and 2 (left and right) to the components, and then take Left + from channel 1, and Right - from channel 2 and connect it to the sub.
You will need capacitors for the components and a coil for the sub.
Winn, the sub's ohm has to meet the amp's minimum requirement. For example, if in bridged mode, it's 4ohms, then that is what you will need. It can't be lower.
4ohms SVC or 2ohms DVC for a single sub will work. If you have 2, then 2 4ohms DVC or 2 2ohms DVC works.
Naras
Thanks Issac,
you saved me from lot of future trouble
Can i use this passive tri-way crossover
http://www.crutchfield.com/S-ehiQmygSKgg/cgi-bin/ProdView.asp?g=82600&id=essenti al_info&i=127TM100
Username: Carguy
Post Number: 3350
That should work, as long as you don't exceed 4ohms for the sub. PPI amp will only handle 4ohms bridged.
Username: Winn
US
thank you so much Isaac.
Username: Winn
US
quick question,
should I mount my amp on the sub box ?? my car is too tight... Honda CRX..
thanks.
Username: Jmacdadd
Holland, MI
Email me and I will tell you all about these amps and where to find some more of them that would best fit your setup!
Username: Carguy
Post Number: 3359
Never mount the amp on sub box. It will cause amp failure over time.
Home > Message Board > Car Audio > Amplifiers > Archive through June 24, 2005 > Is PPI A600.2 enough for a set of com... [ « Previous ] [ Next » ]
