Thread: Very first System |
New member Username: Camaro823
Post Number: 1 Registered: Jun-05
| Posted on Friday, June 17, 2005 - 11:49 pm: |
Hey, I am new to car audio and I am putting a system together. I am not looking to spend a lot, just a cheap system that sounds decent. I own 2 Alpine Type E's (the newer ones) and i'm looking for an amp. I was just wondering if the Infinity 310A Mono amp would be able to work with these. Its a cheap amp but again i'm not looking to spend a lot. Any help would be great Thanks
Post Number: 2 Registered: Jun-05
| Posted on Saturday, June 18, 2005 - 12:06 am: |
I realized i didn't leave much information in the previous post so here is the specs on the infinty amp: http://www.futureshop.ca/catalog/proddetail.asp?sku_id=0665000FS10044432&catid=1 1031&logon=&langid=EN And here is the specs for the alpine type e's http://www.crutchfield.com/S-1Nws3ktUgNG/cgi-bin/ProdView.asp?I=500SWE1242 and remember i have 2 of them, so let me know if this will at least get the job done. Thanks
Silver Member Username: Alias747
MN
Post Number: 245 Registered: Apr-05
| Posted on Saturday, June 18, 2005 - 12:47 am: |
Yeah, you will get the job done, no problem. It sounds like you are going a little more sound quality than loundess. It would be a good idea to put those subs in a sealed box. I hope that is not the price you are paying for that amp though. You could get that amp for much cheaper on like ebay. Take a look: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5782595643 %26 Much better price. Hope that helped. |
Silver Member Username: Thrushdtd
New York
Post Number: 116 Registered: May-05
| Posted on Saturday, June 18, 2005 - 12:49 am: |
looks like 500 rms @ 2ohms will be good. try mtx 421d or alpine M500 look around. good luck |
British Colu...
Post Number: 9 Registered: Jun-05
| Posted on Tuesday, June 21, 2005 - 10:34 pm: |
You know what sucks, few days after my post...my system got jacked...surrey BC sucks ....3rd time I've been broken into there. This time they got everything. My buddy was nice enough to give me his older alpine type e. So now I start over... |
Bronze Member Username: Kunit
Post Number: 28 Registered: May-05
| Posted on Wednesday, June 22, 2005 - 09:54 pm: |
maaaan...that makes me not want to play my music loud because I live in a small town and everybody says...Listen to that system..wouldnt i like to have it...then boom...u wake up the next morning and its gone... |
