Thread: No Bass, where is my problem? |
New member Username: Gurs
London,
London
United Kingdom
Post Number: 1 Registered: Jun-05
| Posted on Thursday, June 16, 2005 - 05:54 pm: |
Hi, this is my 1st posting... I have a Sony head unit, with a sub out, and I recently wired up a Kenwood amp and sub, and it worked fine. Unfortunatly, the power cable came out (someones bag pulled it out...), so I thought I would put it back in, when I did this, there were a few sparks, and the amp didn't work... After that, I: 1) Checked the 2 fuses (near the batt, and on the amp) -> they both look fine. 2) I then bought a cheap amp from eBay, but when I connect it, the protection circuit comes on... I thought it may just be a crap amp... so -> 3) I bought a new Sony amp, however, I connected this and it still doesn't work! I have checked the sub itself, and this works when plugged into my home system. How can I check if the amp is working?? With my 2nd amp, I only needed to plug in the RCA and the remote wires to get the protection light to come on (No 12V power)... Please help, its really p*ssing me off! and costing me too much money! |
Bronze Member Username: Thrushdtd
New York
Post Number: 89 Registered: May-05
| Posted on Thursday, June 16, 2005 - 06:08 pm: |
what awg wire r u using for power? |
London,
London
United Kingdom
Post Number: 2 Registered: Jun-05
| Posted on Thursday, June 16, 2005 - 07:04 pm: |
erm, Im not too sure, Im quite new to all this. I bought an Autoleads amp witing kit, with gold connecters, the power cable is about 5mm thick plus 3-4mm of casing... Hope that helps, but I don't think its the cable as it used to work with the old amp. is there any other fuses I need to think about? |
New York
Post Number: 98 Registered: May-05
| Posted on Thursday, June 16, 2005 - 07:21 pm: |
check your ground |
Bronze Member Username: Tatortot324
Post Number: 38 Registered: Apr-05
| Posted on Thursday, June 16, 2005 - 08:56 pm: |
If your protection light comes on then its 1 of 2 problems check the fuses in your car also and then check the fuse connected to your power cable if u have the normal one the tube fuse thing its a peice of crap they break easy check out someplace like wal mart or meijers or something and pick up a new amp fuse kit and that should solve your problem also check the connections make sure no wires are touching anythign it could also short out things |
New member Username: Earplugsneeded
SAN MATEO,
CA
| Posted on Sunday, June 19, 2005 - 10:21 am: |
ONCE A POWER TOUCHES GROUND 75%OF THE TIME THE WIRE IS NO GOOD AFTER THAT YOU NEED TO START WITH A NEW WIRE- EXPERIENCED THIS B4 TRY KEEPING THE AMP CONNECTED REMOTE & GROUND AND RUN WIRE STRAIGHT FROM(BATT TO AMP) NO CAP NO FUSES AND TEST??????? ALOT OF THE TIMES FUSES LOOK OK BUT NOT THIS WILL TEST THAT ALSO CHECK YOUR REMOTE FOR GROUNDED WIRES MELTS OR CONNECTOR LOSEN GOOD LUCK my first advise givin-hope it works 4 ya
Silver Member Username: Illuminator
Post Number: 604 Registered: Apr-05
| Posted on Sunday, June 19, 2005 - 11:00 am: |
Was your shift key stuck or something? heh |
London,
London
United Kingdom
Post Number: 3 Registered: Jun-05
| Posted on Tuesday, June 21, 2005 - 09:24 am: |
I found the problem! but I don't think I would have without you guys... Basically: I think the ground and power touched each other, and the place where the ground touches the body had oxidised, and there was no proper contact... So, I sandpapered the connection and tried it again, and it worked! Thank you all! |
