Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > Best in dash receiver for about $200 ???
Author Thread: Best in dash receiver for about $200 ???
Username: Jerv04
Hello.. I am going to buy a new cd player... can you give me good choices?? I want that kind of cd players that doesnt need a pre amp... 7 band equalizer, something like that... Please about $200, $250 at most thanks
Username: Kd7nfr
Montpelier, ID
United States
Post Number: 170
So you don't need a preamp or equilizer?
Username: Kd7nfr
Montpelier, ID
United States
Post Number: 172
http://www.crutchfield.com/S-iMiyiZS1VO5/cgi-bin/ProdView.asp?g=300&I=500CDA9830 &cc=07
Look here:
http://www.crutchfield.com/S-iMiyiZS1VO5/cgi-bin/ProdGroup.asp?g=300&cc=07&avf=N
They're usually just been opened, and sent back, no real use, and they're cheap. Also try www.froogle.com
You can not use the preamp, or the EQ, just use the preset ones.
xdrummer03
Jake just buy a new one those sights your not saving much at all. Also if your looking for a deck around $200. Go with the CDA-9847 or the DEH-P4700MP. If you want graphics go $220 and get the DEH-P6700MP
Username: Illuminator
Post Number: 565
True, but they are still saving money.
My suggestion would be a Clarion, more specifically the DXZ445.
Username: Kd7nfr
Montpelier, ID
United States
Post Number: 173
I paid $254 for a CDA-9833 off that site.
Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > Best in dash receiver for about $200 ??? [ « Previous ] [ Next » ]
