Thread: What head unit should i get?? (how cliche) |
Bronze Member Username: Prankstar008
San Diego,
CA
Post Number: 27 Registered: Jun-05
| Posted on Tuesday, June 14, 2005 - 02:27 am: |
My Head unit got jacked along w/ my iPod....so..I need a new HU...I was looking at the following..whats your opinion _________________________________________ Sony....this is the one I had that got jacked, I liked all of its feadures..especialy DSO http://www.crutchfield.com/S-2qFLtfSk1zG/cgi-bin/ProdView.asp?g=300&I=158CDXF571 __________________________________________ Clarion...well respected brand...comes with features that I like...I prefer the layout of this over the Sony http://www.crutchfield.com/S-2qFLtfSk1zG/cgi-bin/ProdView.asp?g=300&I=020DXZ555 ___________________________________________ Blapunkt...Simple layout...attractive faceplace..not to familiar with the brand, but my friend has a sticker of theirs on his car. http://www.crutchfield.com/S-2qFLtfSk1zG/cgi-bin/ProdView.asp?g=300&I=023CASMP54 ______________________________________________ BASICLY...I know a bit about these units allready, I just want other opinions. My budget is $200 and I am opened to other models that I havn't listed. I am also opened to other websites, but crutchfield includes a kit and harness (both of which were jacked from me) for free. What do you think? |
Bronze Member Username: Dominirica012
Charlotte,
North Carolina
US
Post Number: 16 Registered: May-05
| Posted on Tuesday, June 14, 2005 - 09:44 am: |
If I where you out of those following choices I would pick the Clarion although in that price range you should try the Alpine CDE-9845, i have the 43 and its a great head unit |
San Diego,
CA
Post Number: 31 Registered: Jun-05
| Posted on Tuesday, June 14, 2005 - 12:03 pm: |
That alpline would be perfect, but I need an aux input. |
San Diego,
CA
Post Number: 32 Registered: Jun-05
| Posted on Tuesday, June 14, 2005 - 12:19 pm: |
Is there a way to edit posts?...anyways...it has an aux input, but the built-in amp is only 16W RMS and I just sold my external amp with no plans to replace it. |
Silver Member Username: Illuminator
Post Number: 558 Registered: Apr-05
| Posted on Tuesday, June 14, 2005 - 12:37 pm: |
You can go to Edit Profile near the top left, put in your username and password, then scroll down and edit the posts you've made within the past few hours. |
New member Username: H_vltg3
Post Number: 4 Registered: May-05
| Posted on Tuesday, June 14, 2005 - 09:29 pm: |
Unless you spend a lot like 4-500 buck you wont see that RMS go up a whole lot. You mite as well buy another external amp. Shouldn't have sold it. |
