Thread: Trouble with xplod |
New member Username: Arian
Post Number: 1 Registered: Jun-05
| Posted on Saturday, June 11, 2005 - 04:17 pm: |
Hello friends, I just bought a cdx-sw200 xplod. I installed it with out a hitch and everything worked fine. I played the radio for a bit with the car doors (mitsu 96 galant) open. When I shut the back rear door the radio stopped. From that point on I recieved nothing from the radio function, static or other wise. The unit was unable to pick up any stations either; however, the cd player function still works. I took the unit back out, checked all my connections including the cord that goes to the antenna and found no problems. Can anyone shed some insight on this? |
Bronze Member Username: Prankstar008
San Diego,
CA
Post Number: 18 Registered: Jun-05
| Posted on Saturday, June 11, 2005 - 08:36 pm: |
I would try disconnecting the - battery cable and reseting the stereo. Also, double check BOTH ends of the antenna cable. |
