Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > Will this work?heard a rumor about so...
Author Thread: Will this work?heard a rumor about some type of volts I DUNNO
DynOmite
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39752%26item%3D5778935032 %26
A GUY told mentioned somthing about making sure my amp will be able to handle 4v or somthin from this HU... I HAVE NO IDEA WHAT HE WAS TALKING ABOUT will you just tell me if this will be a good with 2 12" kicker cvr's with EITHER a mtx801d(don't have$ for it) or the Audiobahn A800t(BOTH 800W RMS @ 2OHMs x 1)
Username: Iufan4lifeul
Louisville, Kentucky
Post Number: 95
I dunno what he was talking about either. It looks like a decent HU, the one I am looking at is $125 dollars on ebay and is the Kenwood589 or something. The advantages over the one you mentioned is that it has 4v outputs compared to 2.2v (more volts the cleaner the signal to the amp and speakers) and it has a higher CD signal-to-noise 105 compared to 94... How much of a difference will these small things make? MAYBE a little but not noticable unless you crank them both up side by side. Overall decent head unit, if you like it go for it.
Post Number: 96
Something like this for example is what I am looking at...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39751%26item%3D5780388696 %26
DynOmite
yea that looks like a good HU, but i wanted that LCD display(i don't kno why) but i think i'll be fine it's not like im entering compitions tho
and i cant wait to smoke this kid with the same subs i have but hes got a pyle amp hooked up to it.. i thinjk i'll go ported n give me that much more of an advantage
Username: Jeremyc
Germany
Post Number: 721
He was talking about the RCA output voltage, and yes MOST amps will be fine with 4 volts. The only time I worry about it is when your talking about units with 8 volt outputs or so. Thats when you get into an area that amps may not like it.
Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > Will this work?heard a rumor about so... [ « Previous ] [ Next » ]
