Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > CD's not playing or skipping in my So...
Author Thread: CD's not playing or skipping in my Sony Xplod (7 years old)
Username: Marigot
My CD's, new old, scratched, unscratched keep getting error messages and will not play. I have cleaned the unit, tried blowing an air duster into the player. Sometimes after the car has been running a CD will play, but there is no consistent factor. Is something just worn out? I need tunes!
THANKS!!!!
Username: Marley289
Post Number: 185
you should probally just buy a new HU, if its 7 years old then no wonder why its having problems. the thing that reads the CD is probally dirty/scratched/worn out and its not really worth it to get it fixed. i would suggest to get a new one...unless anyone else has any other suggestions
Username: Illuminator
Post Number: 480
They can get a used one and swap CD Mechs...normally that fixes Sony's CD player problems...
Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > CD's not playing or skipping in my So... [ « Previous ] [ Next » ]
