Thread: Sony CDX-M630 |
New member Username: Superdavesyj
Post Number: 1 Registered: Jun-05
| Posted on Monday, June 06, 2005 - 03:29 pm: |
I just bought a used Sony CDX-M630. I installed it in my jeep. It plays fine but I can't figure out how to perset the stations & can any one tell me how the power wires are to be hooked up. Because when I hook it up & turn off the key the clock doesn't save the time & if I hook up bothe the red & yellow wires to full time power it turns it self on & off & won't play. Any help would be great. |
True Green Employee Unregistered guest |
| Posted on Monday, June 06, 2005 - 03:33 pm: |
Whats Happenin Dave Goff :D |
Post Number: 2 Registered: Jun-05
| Posted on Monday, June 06, 2005 - 03:39 pm: |
Do I know You
Silver Member Username: Illuminator
Post Number: 463 Registered: Apr-05
| Posted on Monday, June 06, 2005 - 06:08 pm: |
I think you need the remote to preset the stations and as far as the power issue goes, you should have the red hooked up to the ignition wire which sends out power only when the car is on. The yellow sounds as if it is hooked up properly where it is always receiving power. |
Post Number: 3 Registered: Jun-05
| Posted on Tuesday, June 07, 2005 - 01:23 pm: |
I have the wiring figure out Now if anyone can tell me how to set the stations that would be great. |
Post Number: 4 Registered: Jun-05
By the way I have the remote |
