Thread: Will this be easy????? (pictures included) |
New member Username: Lspade
Glenwood,
Minnesota
United States
Post Number: 1 Registered: Jun-05
| Posted on Monday, June 06, 2005 - 11:03 am: |
My car had a cassette player totally separate from the am/fm radio so I pulled it out. I am hoping to go buy a cheap cd deck probably from Wal-Mart or something and put it where the cassette player was. There are two main wires with connectors left over. Here is the picture of the wire connectors and the old cassette player area: I was wondering if a new cd player installation will be easy and just a point and plug installation? Or will I have to cut the old connectors off and wire everything manually and possibly have to work with stuff in the fuse box?
New member Username: Prankstar008
San Diego,
CA
Post Number: 8 Registered: Jun-05
| Posted on Monday, June 06, 2005 - 05:36 pm: |
you might (will) have to buy a wiring harness.....stay out of the fuse box....just ask any car audio place for a wiring harness that matched the year, make, and model of your car and as long as your not color blind and can plug stuff in, it will be the best $10-$20 you ever spend...it doenst look like it, but you might also need a dash kit....talk to an audio store about that as well |
Silver Member Username: Illuminator
Post Number: 464 Registered: Apr-05
| Posted on Monday, June 06, 2005 - 06:10 pm: |
That's a Suburban, isn't it? |
Bronze Member Username: Nopidy
Post Number: 11 Registered: Jun-05
| Posted on Tuesday, June 07, 2005 - 10:17 am: |
Thnx for the info. ...and it is a blazer.
Post Number: 471 Registered: Apr-05
| Posted on Tuesday, June 07, 2005 - 02:11 pm: |
Good times. |
New member Username: Will_dog
Eugene,
OR
Post Number: 3 Registered: Jun-05
| Posted on Monday, June 13, 2005 - 03:40 am: |
yer both wrong It's prolly a 1500 or 2500 Pickup right side of dash tells me so   |
Bronze Member Username: Prankstar008
San Diego,
CA
Post Number: 26 Registered: Jun-05
| Posted on Monday, June 13, 2005 - 01:53 pm: |
he said it was a blazer.... |
