Thread: DUAL XDV8125 |
Silver Member Username: Monkey_man
Post Number: 130 Registered: May-05
| Posted on Sunday, June 05, 2005 - 06:43 pm: |
Why so cheap?? Is dual that bad? |
Silver Member Username: Illuminator
Post Number: 455 Registered: Apr-05
| Posted on Sunday, June 05, 2005 - 07:55 pm: |
Yeah...very bad... |
xdrummer03 Unregistered guest |
| Posted on Wednesday, June 08, 2005 - 02:18 am: |
There ok subs. Come with 2 12"s and a box for like 150. Just not a big name brand. Almost like Jensen. |
| Posted on Thursday, June 09, 2005 - 01:21 pm: |
Is it possible to make it so you dont have to be in park and have the parking break up inorder to view the TV features. |
| Posted on Friday, June 10, 2005 - 03:30 am: |
Yeh it is possible. Matter of one wire. |
Silver Member Username: Geekbike
Post Number: 140 Registered: Dec-04
| Posted on Friday, June 10, 2005 - 04:53 am: |
I'm not sure if it's wired the same as the flip-out 5"+ decks, but usually the wire meant for the parking brake could be grounded to allow for the deck to play video. |
