Pioneer wiring
Username: Winedrauv
I have a Pioneer deh-345r from my old car, now I want to install it in another car, problem is I dont have the pioneer wiring, it's in the old car, which in turn closely resembles scrap metal nowadays =( ...
Look at the picture below, I need to know which pin is for what in the plug... somebody know?
Upload Upload
Username: Winedrauv
I found this picture, it is a Pioneer 2 x 6 pin (12 pin) connector, should work out fine...
Tiellie
Can you tell me wich wire is for the 12 vdc and wich colors are for the speakers?
Username: Illuminator
Post Number: 557
The same as any aftermarket headunit...Upload
I Have a pioneer 235 and i'm trying to install it in a 99' Grand Am. I have different colored wires coming from the car than the cd player? Need major help? Hint Hint I'm a first timer
Username: Geekbike
Post Number: 197
Go to Canadian Tire and buy a wiring kit. Match up the wires, solder or crimp them, and just plug it all in.
We're trying to crimp them together the problem is making up the wires!! Please Help? Pioneer DEH 235 in a 99'Grand Am!! Thanks for the help
We're trying to crimp them together the problem is matching up the wires!! Please Help? Pioneer DEH 235 in a 99'Grand Am!! Thanks for the help
Post Number: 659
Knacko offered extremely useful advice. Get an aftermarket wiring harness.
If you've already cut the harness, then you might want to browse through the wiring harness thread and check the links in the posts already there.
