Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > Good HU for powering Amp's
Author Thread: Good HU for powering Amp's
Username: Tigger2577
I am looking for a good head unit that will power about 5 amps. 2 for the front componints, 2 for the back componints, 1 for the Subs. I do not plann on using the speaker out form the HU at all.
do not want to spend more than $1000 would perfer to only spend arround $500 or less
Username: Bananakrill
Benicia, California
Post Number: 56
Head units don't power amps. Batteries do. And alternators charge batteries. Head units power speakers sometimes. IMO get a good alpine or eclipse. I have a couple of eclipses but my next one is an alpine. Eclipse 8000 series has 3 preouts. They sound great with a good system.
Username: Jeremyc
Germany
Post Number: 705
Yep Eclipse 8445 for about 550, and the 8455 is about 650. Both are excelent head units, just make sure your amps can handle 8 volt RCA outputs, most of your cheap amps, (sony legasy, boss and so on) can't.
How can you tell how much volts the amp can take. I will be buying Boston Acustics Amps
Username: Qup2cit
Australia
Post Number: 23
those amps can handle 8volt RCAs
Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > Good HU for powering Amp's [ « Previous ] [ Next » ]
