Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > Head unit in the House
Author Thread: Head unit in the House
Superman34
Does anyone know what the least amount of amprige I can use to run a car cd player. I want to run the CD player in my house and was wondering if 12V 1Amp power supply would be enough. I tried 300ma and it would run the radio and lights but kept trying to turn of when i wanted to run a CD. plus the power supply was getting pretty hot.
Username: Illuminator
Post Number: 435
One ampere is the absolute minimum. If all four speaker outputs are being utilized, I would suggest at least eight amperes, though you won't need more than fifteen.
Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > Head unit in the House [ « Previous ] [ Next » ]
