Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > No Power Head unit 00' Jetta blew som...
Author Thread: No Power Head unit 00' Jetta blew something out? please help
Username: Camaro11388
Please help me. I've got a 2000 jetta. Trying to replace 2nd aftermarket stereo. Originally I had a jensen head unit and I took it out to put in a JVC unit. I connected the wires from the jvc with the same color wires that went into the jensen. I think they are all correct. While doing so, the red (ignition?) wire touched the yellow (battery?) wire and I blew the fuse. I changed the fuse and now all that happens is I can eject a cd or load a cd into the head unit but it soon shuts off. It will display the clock but that also soon goes away, even without the key in it. I am pretty sure the radio works fine becuase when I touch the red wire from the head unit to the yellow battery wire it powers up fine with no key even in the ignition. Did I blow something out? Please help me I really dont know what to do from here.
Username: Illuminator
Post Number: 433
It sounds like you fried your igntion wire, however did you check all of the other fuses?
Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > No Power Head unit 00' Jetta blew som... [ « Previous ] [ Next » ]
