Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > Dash mount choices for '89 Dodge
Author Thread: Dash mount choices for '89 Dodge
Username: Videobruce
Buffalo , NY
Post Number: 26
Regarding dash mounts. Scosche has 4 mounts that work with this vehicle ('89 Dodge Spirit). They call them;
Specific kit;
http://www.scosche.com/scosche.aspx?CategoryID=5&ItemID=CJ1282B
ISODIN mount;
http://www.scosche.com/scosche.aspx?CategoryID=5&ItemID=CJ1278B
Multikit,
http://www.scosche.com/scosche.aspx?CategoryID=5&ItemID=FCJ1270AB
RetailISODIN;
http://www.scosche.com/scosche.aspx?CategoryID=5&ItemID=FCJ1276AB
There is also this for a EQ that I won't have;
http://www.scosche.com/scosche.aspx?CategoryID=5&ItemID=FC1235B
Ok, which is what and what is best??
Buffalo , NY
Post Number: 27
I won't be using a EQ, just a basic HU.
Username: Illuminator
Post Number: 425
I think that one is the best, it has a shelf for storing items, overall utilizing the space best. The last one of course has the E.Q. and you don't want a gap in your dash. The first one is O.K. if you don't want the storage shelf, and the other two just involve too many small pieces in my opinion...I hope that helps...
Buffalo , NY
Post Number: 43
That's what I was looking at also. It also moves the opening up a bit.
Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > Dash mount choices for '89 Dodge [ « Previous ] [ Next » ]
