Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > Clarion dxz745mp
Author Thread: Clarion dxz745mp
Hey there i am having a problem installing a clarion cd dxz745mp into a windstar. i have connected the ignition , constant power and earth wires and when i switch the car on the only thing the player will do is make a noise like when it's ejecting a cd and doesnt do more than that. It's already the second dxz745mp wich i try to install and all same...what could be the problem?
Username: Illuminator
Post Number: 419
Can you tell us how you have the wires connected(color-wise) to the windstar's harness? i.e. Ignition connected to Yellow/Black
Also, what year is your Windstar?
Windstar is 1998... Thick yellow (15A)on Clarion connected to green/Black on Windstar, thin yellow (3A) on Clarion connected to Yellow/Black on Windstar, and Black to black of course.
Post Number: 424
Ah, the thin 3A yellow wire should be hooked up to the same wire as the thick 15A yellow wire. In the 3A wire's place, connect the red wire instead.
Miniatar
It works! Thank you VERY VERY match!
Home > Message Board > Car Audio > Head Units > Archive through June 17, 2005 > Clarion dxz745mp [ « Previous ] [ Next » ]
