Thread: Wiring diagrams online?! |
New member Username: Johan
Post Number: 1 Registered: May-05
| Posted on Monday, May 30, 2005 - 08:14 pm: |
hey, i bought an Alpine CDA-9827 and planned on installing it myself but then quickly realized i needed to have some sort of diagram or schematic for wiring it cause the wires themselves arnt labeled. there was nothing in the box to that effect so does anyone know if there are diagrams available online or somfing? THANKS! |
Silver Member Username: Illuminator
Post Number: 387 Registered: Apr-05
| Posted on Monday, May 30, 2005 - 10:37 pm: |
Are you looking for the headunit wiring diagram? Hopefully this is it... The Blue/white wire(which is missing from this diagram) is the amp remote turn on.
Unregistered guest |
| Posted on Saturday, June 04, 2005 - 11:10 pm: |
where did you get that diagram? are there similar ones available for other units? |
Post Number: 446 Registered: Apr-05
| Posted on Saturday, June 04, 2005 - 11:55 pm: |
www.bcae1.com Under Head Units #22 in the directory. It's a very basic diagram...is there something that I can help you with, though? |
