Thread: Alpine EQ anygood? |
New member Username: Linearpowers1
SF,
Ca
SF
Post Number: 2 Registered: Mar-04
| Posted on Sunday, March 07, 2004 - 08:47 pm: |
Hi All,I've got an Alpine 9813 and need to know if the built in EQ is good quality or would I be better off with a external EQ? |
NorthWest,
Michigan
Post Number: 1535 Registered: Dec-03
| Posted on Monday, March 08, 2004 - 11:22 am: |
the internal sound shaping and parametric EQ is great. The only time you ever really need an EQ, is when you need to compensate for a poor choise in speakers, or a bad acoustic environment. It's a compensation tool, and not something you want really just to mess with sound curves all of the time. Once the system is tuned correctly, you should never need to mess with an EQ.
Bronze Member Username: Beligerant1
NC
Post Number: 13 Registered: Apr-04
| Posted on Friday, June 04, 2004 - 10:41 am: |
So how do i know if my system is tuned correctly? Haha, im sure my car is a bad environment, its a 1991 isuzu trooper. I did put some dynamat in though. I have the 9815 and am in the process of adding a sub and amp. After that I would like to use the HU to adjust all the crossovers so the front and rear speakers only get the signals they need (Im not sure but hopefully that will utilize the power of the internal amp better). But as far as using the equalizer im in the dark. How do you know which frequencies to adjust, and to what extent? |
NorthWest,
Michigan
Post Number: 3397 Registered: Dec-03
| Posted on Thursday, June 17, 2004 - 01:44 am: |
either do it by ear, or go to a shop that has an RTA, and let them adjust the EQ using their RTA and a mic.
