Thread: JVC KD-LH810 vs Pioneer DEH-P6700MP |
Bronze Member Username: Basketballinu05
Post Number: 71 Registered: Dec-04
| Posted on Tuesday, May 24, 2005 - 11:34 pm: |
ok i can get the jvc for 5$ more than the pioneer which hu should i get?http://www.cardomain.com/item/PIODEHP6700MP http://www.cardomain.com/item/JVCKDLH810 |
Silver Member Username: Illuminator
Post Number: 331 Registered: Apr-05
| Posted on Wednesday, May 25, 2005 - 12:08 am: |
I'm not going by what the site says, but the Pioneer is absolutely the best deal out of the two. I don't even see how JVC can charge so much for that piece of crap. |
Post Number: 72 Registered: Dec-04
| Posted on Wednesday, May 25, 2005 - 08:19 pm: |
but if u look at the specs the jvc has better ratings |
Post Number: 334 Registered: Apr-05
| Posted on Wednesday, May 25, 2005 - 08:55 pm: |
It might have slightly better features...but it looks like it has about the same power specifications as the Pioneer(except the JVC has 4v preamps as opposed to Pioneer's 2v). Ultimately, it all matters what features you're looking for...the JVC does indeed have mp3 where the Pioneer doesn't, but the Pioneer will last a great deal longer and have better sound quality. |
Gold Member Username: Taylor17
Kopperl,
Texas
Post Number: 1850 Registered: Jan-05
| Posted on Thursday, May 26, 2005 - 08:12 am: |
Both are great HU's, just go with the one you like the best... P.s, I have a JVC HU, and a Pioneer Premeer, and both are great. You might get a little better quality, and maybe last a little longer with the Pioneer. |
| Posted on Friday, May 27, 2005 - 05:52 pm: |
I was trying to decide between the two as well. I'm going to be using an external amplifier though, so I don't even care about the power ratings of the internal amps. Does that mean that since the JVC has 4V preouts, I'll actually get a better sound from my external amp? |
| Posted on Saturday, June 04, 2005 - 05:30 pm: |
Jexxen, do you even know what you are talking about? the Pioneer does have MP3, if you took the extra 2 seconds to click the link and read. I've got the JVC 810 CD player and it's great. I don't know how you can make a blanket statement that the Pioneer will last longer and sound better just cuz it's a Pioneer. Yes Pioneer is good but by no means the ultimate in quality. I'm very impressed with the JVC. Preouts have nothing to do with better sound per say, but higher voltage means you can adjust your gain on your amp accordingly....more voltage basically means less gain. here's a good explanation: http://forum.soundillusions.net/showthread.php?s=41d04235a9678727b87cbf854baab88 9&p=529585#post529585 The key things about the JVC over the Pioneer for me are these: Burr-Brown 1-bit digital-to-analog converter has full 24-bit resolution # Dual 4-Volt Gold-Plated Preamp Outputs # Gold-Plated Subwoofer Output with Level Control CD Signal-to-Noise Ratio: 102 dB All these things are better then the Pioneer. Wheather they are important to you i dont know.
Post Number: 440 Registered: Apr-05
| Posted on Saturday, June 04, 2005 - 07:37 pm: |
I knew my posting that the JVC is a piece of crap would evoke someone who owned the unit to be upset. And honestly, it is crap. I've owned 3 JVC headunits, all of which are partially functioning now with the main problem being the heatsink location and design. The faceplate is also made of cheap plastic, I bet when you click the buttons on your JVC, it's louder than the music you play. Actually, the preamps, 102dB, and fake 24bit CD player are the only things where the JVC is better than the Pioneer sound-wise. Everything else is the same, or Pioneer is better. Surprise, surprise. JVC owners remind me of Chevy owners, they mistakenly believe they have the best and everything else is trash. |
Silver Member Username: Spittin2rock
Post Number: 116 Registered: Mar-04
| Posted on Tuesday, June 07, 2005 - 01:23 pm: |
well usually when people use the controls on a head unit they press the buttons not punch them. Or maybe you shouldn't own a head unit period if you manage to break 3 JVC's. My first unit was a Pioneer and it lasted about a year and a half then it kept blowing the fuse. Some internal was blowing the fuses. Bought a JVC right after that and that puppy is still working like a champ. I've had it now for about 5 years. I just bought another JVC for my Explorer and to work with my CD changer and that CD receiver is great. Then I bought a used Pioneer DEH-7000p which is a fairly old cd player for my Honda Civic. The owner before me had it approximately 2 1/2 years. I've had it now for 1 1/2 years. That puppy still puts out good sound also. The only flaw with that one is the volume up button broke so you have to use a pen or the remote to put the volume up and also the sub-out is bad. So both are very good units and both a pretty durable. So take your choice you will enjoy either. |
Post Number: 473 Registered: Apr-05
| Posted on Tuesday, June 07, 2005 - 02:17 pm: |
Sorry if I came across as harsh, but it has just been so bland in this forum... |
xdrummer03 Unregistered guest |
| Posted on Wednesday, June 08, 2005 - 02:16 am: |
Just to clear things up where Jexeen mislead you,the pioneer 6700 is mp3 compatible.Pioneer is a better deck for the price. Better quality as far as being able to tune more. |
Post Number: 483 Registered: Apr-05
| Posted on Wednesday, June 08, 2005 - 02:36 pm: |
I mislead them? Lies! I said the Pioneer was clearly the better choice. At the time I posted saying the Pioneer didn't have mp3, I was going by the previous models (the p6400, the p6500, and the p6600) which never had mp3 up until this point. |
| Posted on Wednesday, June 08, 2005 - 08:31 pm: |
In your second post your comparing them saying the 6700mp doesnt have mp3 and JVC does. I was just telling him it does. |
New member Username: Sublover
Lacrosse,
MN
U.S
Post Number: 5 Registered: Jun-05
| Posted on Monday, June 13, 2005 - 12:52 am: |
Just for the record best buy sells all of those units and the JVC's have a higher return rate because the power button gets stuck in. So simply for durability I would go for pioneer, but if you like the features on the JVC just get a waranty. |
Silver Member Username: Geekbike
Post Number: 154 Registered: Dec-04
| Posted on Monday, June 13, 2005 - 03:04 am: |
The Pioneer is the better deal. - much, MUCH better EQ - better internals (laser pick-up and onboard amp) - navigation is much simpler - better processor with less distortion - BMX enhancement and wav playback S/N ratio is meaningless - anything over 90db is an inaudible difference The only thing the JVC has going for it is the 4v preouts. Maybe the rear preout if you actually use rear speakers. |
| Posted on Monday, June 13, 2005 - 03:55 pm: |
Pioneer does have the better balance all around. Also Kyle I dont think the power button will break within 30 days. |
Lacrosse,
MN
U.S
Post Number: 10 Registered: Jun-05
| Posted on Monday, June 13, 2005 - 06:22 pm: |
No, but best buy has a 2 or 4 year waranty, thats what I'm talking about. |
