Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through April 16, 2004 > Kappa help
Author Thread: Kappa help
Username: Snoopy111
I have a pair of kappa 6.5 ran by a us acoustics 4 channel amp. for some reason, they give me a huge headache and make my ears hurt when i listen to them. is there anything i can do short of replacing these speakers. Has anyone had this problem and found a good alternative?
Username: Glasswolf
NorthWest, Michigan
Post Number: 1516
stop turning them up so loud.
Username: Snoopy111
are you serious? do kappas generally give fatigue when turned loud? or are you just being a smart a**??
Username: Glasswolf
NorthWest, Michigan
Post Number: 1526
anything turned up too loud will give you a heacache.
You may also have them wired out of phase, or any number of other issues.
have a qualified installer listen to the system and see if s/he hears anything out of whack. The installer can then suggest possible problems.
It's hard to do from here though.
Username: Its_bacon12
Post Number: 209
they have 3 choices on the x-over, +5 db, +/- 0 dB and -4 dB..
i have mine on -4 dB and they still get to the point where i get a headache and my ears ring lol
Post Number: 212
im only talking about the 6.1 component set or 5.1 btw
Username: Snoopy111
unfortunately, the kappa coaxes have an electronic passive x-over... any other suggestions? I've spent alot of time on this, and i am on the verge of buying an new pair of speakers.
Username: Tbone
OK
United States
Post Number: 115
tune the speakers with the gain controls on the amp. Set the gains where the speakers play at a comfortable level for you when you have the HU cranked.
josh
should i buy the infinity kappa speakers 9603i or infinity reference speakers 6935i? thanks
Username: Tbone
OK
United States
Post Number: 188
Kappa's.
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through April 16, 2004 > Kappa help [ « Previous ] [ Next » ]
