Thread: Best high-end HU?? |
Bronze Member Username: Masse1369
Post Number: 25 Registered: Apr-05
| Posted on Sunday, May 22, 2005 - 03:53 pm: |
i was looking at the: nakamichi cd700ii pioneer p9 or p860mp clarion drz9255 eclipse cd8455 has anyone had any good or bad experience with these? what would you buy? (too bad i dont have $6500 for the alpine f1 status with multimedia manager) any comments would be very helpful, thank you. |
Post Number: 26 Registered: Apr-05
| Posted on Sunday, May 22, 2005 - 03:55 pm: |
by the way, i was going to be using the new 07 cdt components but decided on the morel elate series with supremo tweeter instead for front stage. morel elate midbass for rear stage. dls ultimate iridium 15 subwoofer and tru amps and stinger wiring. |
Post Number: 27 Registered: Apr-05
| Posted on Sunday, May 22, 2005 - 03:57 pm: |
btw, the premier p860mp seems to be a very good value for what you get. |
Gold Member Username: Jonathan_f
GA
Post Number: 3968 Registered: May-04
| Posted on Monday, May 23, 2005 - 12:13 am: |
If you want the most processing capability, the Pioneer P9 combo is a great head for the money. Other than that, all of them are great units and will perform very similarly to one another, I'd probably choose the Clarion because of the 96khz K grade DACs, then the Nak or Eclipse. Whatever you like the look/feel of basically. |
| Posted on Monday, May 23, 2005 - 11:40 am: |
Im getting a Denon head unit, it sounds real good, just try to listen to all of them see what one u like |
yelnatsch517 Unregistered guest |
| Posted on Thursday, May 26, 2005 - 02:36 am: |
Wow, I was just wondering why they those Clarions are being compared with the rest when it is more than twice as expensive? With that said, what would be the best one with a $600 budget (give or take $100). |
