Home > Message Board > Car Audio > Speakers > Archive through May 25, 2005 > Dashboard or doo panel
Author Thread: Dashboard or doo panel
Ron Mexico
My car will accept a 3 1/2" speakers in the dash or 5 1/4" inch in the door. The door enclosures are all the way to the back of the door, where your behind (I can't believe I can't say a s s in here like a normal person) would be in the seat. Which would be the better option given that its not easy to find a good 3 1/2" speaker and its much easier to find a much better set of 5 1/4" speakers, even nice component ones. Also does anyone have a speaker recomendation or a website to order from? Thanks
Username: Mikechec9
Chicago/atlanta
Post Number: 56
woofersetc.com. 1-2yr warranty AND phone number. save the loot and get a custom install. 3'1'2 will give you no bass extention up front. had 95 rodeo w/4in. sux.
w/ 5.25, the imaging behind yourass will be very poor. save up. go custom. or get those qlogic kick panel inserts, but you will have to seal them from the bottom. they are hollow
Home > Message Board > Car Audio > Speakers > Archive through May 25, 2005 > Dashboard or doo panel [ « Previous ] [ Next » ]
