Thread: 6x9s |
Bronze Member Username: Shadylimitedx
Pgh,
Pa
Usa
Post Number: 73 Registered: Apr-05
| Posted on Thursday, May 19, 2005 - 06:40 am: |
i got 2 volfenhag 6x9s 800 watts at 4ohms a pieace an i was wondering if i run the wire of the 1 2 the other 6x9 will it be runnin at dual 4ohms / 2ohms so i can get the right amp wit a cross over |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 571 Registered: Mar-05
| Posted on Thursday, May 19, 2005 - 07:55 am: |
1. Those are overrated.800 watts RMS? I would guess them to be more around 80 watts RMS. 2. I would not suggest raising or dropping ohm loads on regular speakers. If you want speakers with more handling power then buy better ones. 3. To answer your question, I would need to know how they going to be connected. Go to www.rockfordfosgate.com, thrn go to tech support, then woofer wiring wizard. Punch in your info and it will show you what you want to know. |
Pgh,
Pa
Usa
Post Number: 75 Registered: Apr-05
| Posted on Thursday, May 19, 2005 - 08:19 am: |
there speakers an i like them an they sound good an thats the point just need a amp for music power not bass |
Pgh,
Pa
Usa
Post Number: 77 Registered: Apr-05
| Posted on Thursday, May 19, 2005 - 09:05 am: |
an thankx for the web site now i can get the right wireing an cubit ft |
