Thread: *A CD/MP3 playing problem*- clarion dxz835mp head unit |
New member Username: Dirtjumpersb
Eagle River,
WI
United States
Post Number: 1 Registered: May-05
| Posted on Wednesday, May 18, 2005 - 10:32 pm: |
hey when i put a cd into my headunit, it loads and shows on the display likes its playing( the little track and timer display goes and stuff), but there is absolutely not sound heard. i have no idea why this is. i took this headunit out of a previous vehicle and when i re-installed it, i had this problem. The radio works and sound is heard, so its not the wiring or the speakers. . . some help would be greatly appriciated. Thanks-steve |
Gold Member Username: Fishy
Tamarac Ft.Laud,
FL
Post Number: 1287 Registered: Sep-04
| Posted on Wednesday, May 18, 2005 - 10:55 pm: |
Wow, if the display shows it is playing then you should be getting some output. Might be something major like a bad DAC or something. I'd give Clarion a call. This is happening with regular non-MP3 encoded CD's as well, right? If not then check the manual: http://www.teamclarion.com/sharedwebdbs/ClarionSupport.nsf/b519d112bdcca8b588256 a630071fab1/6fac797e6a09d8ef88256cc50062c6d5/$FILE/DXZ835MP.pdf MP3's need to be recorded in a certain logical format in order to operate correctly, but if the display shows the cd playing I'd think the thing should be working regardless. -Fishy |
Silver Member Username: Illuminator
Post Number: 238 Registered: Apr-05
| Posted on Wednesday, May 18, 2005 - 11:26 pm: |
Are the speakers running off the internal amp? |
Tamarac Ft.Laud,
FL
Post Number: 1290 Registered: Sep-04
| Posted on Wednesday, May 18, 2005 - 11:28 pm: |
My initial thoughts as well, but if the radio works......... -Fishy |
Post Number: 240 Registered: Apr-05
| Posted on Wednesday, May 18, 2005 - 11:58 pm: |
If he is using all external amps...he might have accidentally switched the amp remote turn on wire with the antenna turn on wire coming from the headunit... |
Tamarac Ft.Laud,
FL
Post Number: 1294 Registered: Sep-04
| Posted on Thursday, May 19, 2005 - 12:06 am: |
Yeah, but why does the radio still work? weird -Fishy
Post Number: 241 Registered: Apr-05
| Posted on Thursday, May 19, 2005 - 12:20 am: |
In theory, the amps would only be receiving a signal as if they were a power antenna-the headunit sends out a signal to turn them on during FM/AM reception and turns them off during any other function. |
Tamarac Ft.Laud,
FL
Post Number: 1297 Registered: Sep-04
| Posted on Thursday, May 19, 2005 - 02:43 am: |
Ahhhhhh....... thats probably it. My first Alpine tape deck had no remote wire and you had to use the power antenna lead. I guess that doesn't always work with today's stuff. He ought to check the amp's power LED with radio and cd modes and see if the amp is shutting off. -Fishy |
Eagle River,
WI
United States
Post Number: 2 Registered: May-05
| Posted on Thursday, May 19, 2005 - 09:18 pm: |
thanks guys, im gunna go check it out tonight. so let me get this staight, i have to check and make sure the amp wire is hooked up corectly? that just means making sure the wires are hooked up properly right? i have an amp i could put in if you think that is the problem. once again, thanks for the help -steve |
Eagle River,
WI
United States
Post Number: 3 Registered: May-05
| Posted on Thursday, May 19, 2005 - 09:28 pm: |
now that i re-read it, i think you're under the impression that i am using an external amp, but im using an interal at the moment. so whats your suggestions for that? or am i misunderstanding? i was running an external amp with cdt components but one speaker stopped working all together. i checked the wiring and that wasnt the problem? i have bad luck with this stuff. so do you guys have any suggestions there? well thanks alot for all your help so for -steve |
Tamarac Ft.Laud,
FL
Post Number: 1306 Registered: Sep-04
| Posted on Friday, May 20, 2005 - 01:32 am: |
If the display says the cd is playing and you're using the head unit's amp only then there's something wrong with the h/u(bad DAC?). Call Clarion -Fishy |
