Thread: Need Opinions. |
New member Username: Blitz666
Post Number: 3 Registered: May-05
| Posted on Wednesday, May 18, 2005 - 07:35 pm: |
Ok here's the deal.. I have just ordered a system from overseas and i'd like to know if you guys think it's worth the money.. JBL A6000GTI 6000watt Amplifier Power Output: 2600 Watts RMS x 2 channels at 4 ohms. 8110 Watts RMS x 1 channel at 4 ohms, 14.4V supply. 7400 Watts RMS x 1 channel at 1 ohm, 14.4V supply. Signal-to-Noise Ratio: 65 dBA (reference 1 Watt into 4 ohms) Dynamic Power: 6854 Watts at 4 ohms Effective Damping Factor: 6.39 at 4 ohms Frequency Response: 10Hz to 270Hz (-3dB) Maximum Input Signal: 8.5V Maximum Sensitivity: 250mV Output Regulation: .2 db at 4 ohms $6,000 U.S JBL 608GTI 6-1/2" 2-way component speaker system Power Handling, RMS: 150 Watts Power Handling, Peak: 600 Watts Frequency Response (¡À3dB): 50Hz - 21kHz Sensitivity (2.83V @ 1m): 89dB Impedance: 4 Ohms Crossover Frequency(ies): 3.5kHz, 24dB/oct Mounting Depth: 2-11/16" Woofer, 1-1/8" Tweeter $700.00 U.S 3x W15GTI 15" JBL Subwoofer Sensitivity: 92dB @ 2.83V/1m Power Handling: 800W RMS, 5,000W Peak Impedance: 3 or 12 ohms Frequency Response: 16Hz ~ 1kHz Voice-Coil Diameter: 3" (76mm) Mounting Depth: 10-1/4" (260mm) Overall Diameter: 5-1/4" (388mm) Cut-Out Diameter: 13-7/8" (353mm) Displacement: 0.174 ft3 (4.93 l) $699.00 U.S Clarion VRX755VD DVD Center Unit with Direct iPod Interface $1,600 Worth the money?? |
Gold Member Username: Fishy
Tamarac Ft.Laud,
FL
Post Number: 1282 Registered: Sep-04
| Posted on Wednesday, May 18, 2005 - 09:42 pm: |
Don't forget a couple custom 300 amp alternators to power that beast.
-Fishy |
New member Username: Unpiled_acorn
Rockland,
Ontario
Post Number: 8 Registered: Mar-05
| Posted on Wednesday, May 18, 2005 - 11:10 pm: |
lol ya but seroiusly your gonna need some seroius capacitors for that amp wow still dumfounded by that amp |
Tamarac Ft.Laud,
FL
Post Number: 1289 Registered: Sep-04
| Posted on Wednesday, May 18, 2005 - 11:27 pm: |
Those things are HUGE too: http://www.oznium.com/gallery/photos/full/9659/spkrman-chevrolet-monte-carlo hehe -Fishy |
Silver Member Username: Illuminator
Post Number: 239 Registered: Apr-05
| Posted on Wednesday, May 18, 2005 - 11:30 pm: |
Wouldn't the sub be extremely overpowered? |
Tamarac Ft.Laud,
FL
Post Number: 1292 Registered: Sep-04
| Posted on Wednesday, May 18, 2005 - 11:55 pm: |
He's going with 3 of them, but yeah, they're only rated for 800 watts rms each. Lol, I hope this ain't going into a CRX or something. :P -Fishy |
Bronze Member Username: Mikechec9
Chicago/atlanta
Post Number: 49 Registered: May-05
| Posted on Thursday, May 19, 2005 - 12:25 am: |
world champs had similar setups. gary biggs and mark eldridge (team gates jbl) took it all home. great set up man. those subs are very deep. you must have a bunch of room to play with. http://www.teamgates.org/gary_biggs.html |
Tamarac Ft.Laud,
FL
Post Number: 1296 Registered: Sep-04
| Posted on Thursday, May 19, 2005 - 12:54 am: |
Wonder what he plans on powering those components with? Regardless, one set of 6 1/2" components will defintely not be enough to keep up with those subs. I guess he could turn down the sub-out level at the h/u if he actually wants to enjoy some music. Thats going to be one crazy loud setup.
-Fishy |
Bronze Member Username: Justintoxicated
Post Number: 54 Registered: Jan-05
| Posted on Thursday, May 19, 2005 - 02:02 am: |
No Kidding, I want 2 sets of components jsut to match my 10 inch Kodas that I plan to purchase let alone 3 15's! |
Post Number: 4 Registered: May-05
| Posted on Thursday, May 19, 2005 - 02:10 am: |
yeah.. i've hooked up 2 batteries to it LOL.. yeah i got a custom box setup that i plan on using.. for the subs and amp.. i need to re-inforce my glass and the chasis of my car.. otherwise it will either crack or become warped... hope it goes well  |
Tamarac Ft.Laud,
FL
Post Number: 1298 Registered: Sep-04
| Posted on Thursday, May 19, 2005 - 02:46 am: |
Headline: "JBL AMP Warps Car Frame" "Insurance Adjusters are Baffled" hehe -Fishy |
Post Number: 5 Registered: May-05
| Posted on Thursday, May 19, 2005 - 08:44 am: |
Ha Ha, true true, that would be the first..!! |
