Home > Message Board > Car Audio > Head Units > Archive through May 27, 2005 > Removing Alpine 9855 from Celica 2005
Author Thread: Removing Alpine 9855 from Celica 2005
Username: Crowkid
I just got the 9855, love it. One problem though, my cd is stuck in there, open won't work, and also the tilt function doesn't work either. Among a few other problems, I need to send it back to the manufacturer.
Here are some pics of it on my car to get an understanding:
http://www.pix05.com/f/headunit35031.jpg
http://www.pix05.com/f/headunit24547.jpg
http://www.pix05.com/f/headunit14726.jpg
Does anyone know of any guides on the web to do this correctly on a Celica? I have no idea what tools I would need to get it out of there. I'm super newb. Any help is appreciated!
Username: Illuminator
Post Number: 225
I would try to slide the unit out of the metal sleeve it's in by removing the trim ring and pushing the tabs in on the sides of the unit itself with a flat-head screw driver or equivalent. All headunits have different places with which to do this, so you might have to work at it a bit to remove it.
AngryApe
I have the alpine 9853 and I same problem with the cd being stuck and the tilt not working. I just kept pressing the reset button (about 6 times) until it opened and ejected the cd.
Home > Message Board > Car Audio > Head Units > Archive through May 27, 2005 > Removing Alpine 9855 from Celica 2005 [ « Previous ] [ Next » ]
