Thread: Oh god please help me! PUHLEEEZ! |
| Posted on Tuesday, May 17, 2005 - 06:00 pm: |
I need to find a good pair of 6x9s. I had little knowledge so i went on to look for some kickers coz i heard that they were good. but now that i gather more information, the more i get confused!. NOw i've sorted out some speakers for me. please help me choose: Rockford fosgate power series --> outta my budget Soundstream Tarantulas and edge. say that they have 150 and 200W rms. is that fo real? are htey good? they look cool tho. MTX : just 100W RMS? i mean that sounds less when compared to the others. Audiobahn : i researched that thses were the ones with most rms output. 200-225 in diff models. but i just came across someone critising audiobahn for just being a looker and not a performer. i had my heart almost set on these until now. Blaupunkt Overdrive ODX series. I'm gonna get these if i cant decide at all Please help me |
Gold Member Username: Carguy
Post Number: 2981 Registered: Nov-04
| Posted on Tuesday, May 17, 2005 - 08:56 pm: |
Instead of wasting your money on 6x9 speakers, replace them with 6.5" components. It'll sound much better. |
| Posted on Wednesday, May 18, 2005 - 05:48 pm: |
thanks a lot for your input isaac. but i really cant afford components and besides i already have 6x9s in my car and do not want to alter the hole made in any way. I'm on a serious budget and am upgrading my system slowly. these 6x9s will be running straigh off the HU not even an amp. that's next on my list. so pls if you could recommend some from my selection. It'll be very helpful. Thanks a lot |
Bronze Member Username: Mikechec9
Chicago/atlanta
Post Number: 43 Registered: May-05
| Posted on Wednesday, May 18, 2005 - 06:29 pm: |
whats your budget? |
Chicago/atlanta
Post Number: 44 Registered: May-05
| Posted on Wednesday, May 18, 2005 - 06:35 pm: |
regardless, if i absolutely had to go w/6x9 instead of 6.5, i would hit up the infinity ref's. either the 9612i or 96131 for the complete experience. had a pair of alpine 6x9 and they were hitting harder than most anything in the highschool lot (about a decade ago). they would be my 2nd pic. |
Silver Member Username: Loc_out
Post Number: 186 Registered: Feb-05
| Posted on Wednesday, May 18, 2005 - 06:37 pm: |
I would keep on saving that way you dont have to replace them later. |
| Posted on Wednesday, May 18, 2005 - 09:16 pm: |
thanks a lot guys. i checked up on the infinity reference series. they seem to the sweet spot. but just one question. does the high rms on audiobahns have any advantage? my budget would be around 120$ give or take. mtx audiobahn and blaupunkt all are within my range. the kappa series isnt though. so what do you say? loc its not really the matter of saving. i just dont want to spend that much on car audio. i mean right now i have some temporary pioneer 40w rms 6x9 one of which is torn. i still think they igve out good sound. so i beleive high end 6x9s will be good for me. thanks for the advices. |
Post Number: 2996 Registered: Nov-04
| Posted on Wednesday, May 18, 2005 - 10:10 pm: |
If you care about sound quality, then stick to Infinity. I had them in my car, and it sounded very clear. Sometimes the high rms powers the manufacturers use, are all lies. Wait till you actually try and supply some. It'll distort and crack. |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 568 Registered: Mar-05
| Posted on Thursday, May 19, 2005 - 03:04 am: |
Anyway, if you're going to be running the speakers off your head unit the RMS is a moot point because you'll only be supplying those speakers with probably around 20 watts. I would get the Infinities, if you don't mind purchasing on eBay you can get the Kappas rather cheap. Heres a link http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=58029%26item%3D5775949558 %26%26 |
| Posted on Thursday, May 19, 2005 - 11:55 am: |
hmm and what would be a good pair of 13cm or 16cm speakers for the front? should i go with infinity here too?
| Posted on Tuesday, May 24, 2005 - 12:11 pm: |
Hi there again. I've been rethinking about what speakers to buy for my rear. and the thing is that infinity kappa 6x9 3 ways and Infinity Reference 6500s Component speakers are exactly the same price. so i need your opinion again. Will the reference be better than kappas coaxials? and if i install these 6.5" where my 6x9 are right now. the hole will need to be just a bit widened up right? Or will i need a new tray. Help again please. thanks a lot |
| Posted on Tuesday, May 24, 2005 - 12:12 pm: |
