Thread: Foam baffles for door speakers???Jonathon , Glass??? |
Bronze Member Username: Transam396
Mcdonough,
Ga
Usa
Post Number: 11 Registered: Apr-05
| Posted on Sunday, May 15, 2005 - 10:02 pm: |
hi I have a 04 F150 supercrew that i'm putting 4 infinity 5x7 ref speakers I have heard some ppl say to use the foam baffles that u put behind the speaker to tighten up the sound and make it sound better is this a good investment as money is tight??? |
Gold Member Username: Jonathan_f
GA
Post Number: 3928 Registered: May-04
| Posted on Sunday, May 15, 2005 - 11:56 pm: |
They kill your midbass response. Only use IMO is to protect the speakers from water, but in a well sealed door that shouldn't be an issue anyway. Me personally, I'd rather invest the time and money into sound deadening the door, it will improve SQ, reduce outside road noise, improve your midbass response, and raise the apparent volume level because of the road noise being lowered. |
Gold Member Username: Suleman36
Post Number: 1241 Registered: Feb-05
| Posted on Monday, May 16, 2005 - 11:36 am: |
Hey jonathan i have image dynamic id chamoleon midbass speakers. I got some foam speaker baffle online. If i cut the circle in half off the foam baffle at the bottem where the speaker magnets is will it be ok to do. I just wanna keep it tight and dry so water wont get inside. Is that a good idea. |
Gold Member Username: Carguy
Post Number: 2961 Registered: Nov-04
| Posted on Monday, May 16, 2005 - 11:50 am: |
MO, never cut holes in the baffle without first listening to your speakers. That's like punching a hole in a sub box randomly. If you do have to make some, start with small hole, then increase the number of holes as needed to obtain desired sound. |
Post Number: 1244 Registered: Feb-05
| Posted on Monday, May 16, 2005 - 02:16 pm: |
Hey isaac i ordered that foam speaker baffle from installer website you gave me. I just dont wanna kill my midbass with them. The user E on here told me to cut out half the circle on the bottem.. So im not sure |
Post Number: 2965 Registered: Nov-04
| Posted on Monday, May 16, 2005 - 03:03 pm: |
I would first listen to your speakers then determine what's needed. Once you make a hole, it's permanent. Sometimes 1/2" hole is all that's needed to tune a baffle. No need to make a large one. |
Post Number: 1246 Registered: Feb-05
| Posted on Monday, May 16, 2005 - 03:39 pm: |
so a small tiny circle is what i should try before anything. |
Post Number: 2967 Registered: Nov-04
| Posted on Monday, May 16, 2005 - 04:54 pm: |
Only if it's required. Try listening. |
Post Number: 1250 Registered: Feb-05
| Posted on Monday, May 16, 2005 - 08:31 pm: |
So first listen to it with the foam baffle on right? |
Post Number: 2968 Registered: Nov-04
| Posted on Monday, May 16, 2005 - 08:46 pm: |
Yes, who knows, you might like the sound you get without holes. I've tested mine and for the setup I have, it works great. I don't need to punch any holes. But then again, I did tell you, I have 2 sets of components on my front door, one for mid bass (air tight enclosure) and one for midbass and midrange (baffle). |
Post Number: 1251 Registered: Feb-05
| Posted on Monday, May 16, 2005 - 09:03 pm: |
air tight meaning no baffle just mounted to the door with dynamat i assume |
Post Number: 2971 Registered: Nov-04
| Posted on Monday, May 16, 2005 - 10:49 pm: |
Nope, I made air tight enclosure with sound densening material inside out of 6" pvc pipe. I sealed all the joints/screws with glue and goop. It dries to semi hard finish. The speaker is like a rock. You can't really push it in with your finger. However, once power is supplied, it moves very fast.
Post Number: 1260 Registered: Feb-05
| Posted on Tuesday, May 17, 2005 - 12:03 am: |
well we will see how this foam baffle works out. You recommended it so lets wait and see. |
Post Number: 2975 Registered: Nov-04
| Posted on Tuesday, May 17, 2005 - 09:12 am: |
Remember, listen carefully before drilling holes. If with baffle and without makes only 1%-3% sound difference, then it's best to not make any holes. Baffle sealed help your speaker from bottoming out under heavy bass. That and weather proofing are 2 main reasons why people get it. |
Post Number: 1264 Registered: Feb-05
| Posted on Tuesday, May 17, 2005 - 01:12 pm: |
I will let you know if it helps or not. |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 433 Registered: Oct-04
| Posted on Tuesday, May 17, 2005 - 02:51 pm: |
Hey Issac, do you happen to have any pictures of your setup at all? You can email me at arsonicconvergen@hotmail.com if you want to send some. I was just curious to see it. Sorry, didn't mean to hijack this thread or anything. |
Post Number: 2980 Registered: Nov-04
| Posted on Tuesday, May 17, 2005 - 04:23 pm: |
I have no pictures yet. Still working on my car. I've just added 10m/11m CB radio in my car along with 200w booster. Now I'm looking for some kind of blinds for my car windows so that I can pull it down when parking. Just don't want crooks to look inside my car. The hard part is balancing what's practical with looks. Last thing you want is an ugly looking car. Maybe one day, I'll take some pictures. I also have infra red camera installed at the back. It lets me see in the dark (almost). Great when parking at night. |
Post Number: 1269 Registered: Feb-05
| Posted on Tuesday, May 17, 2005 - 04:41 pm: |
Isaac has a 007 Car... |
