Home > Message Board > Car Audio > Speakers > Archive through May 25, 2005 > Hey Johnathan ??? on Focal Utopias
Author Thread: Hey Johnathan ??? on Focal Utopias
Username: Skyliner17
Saint Paul, MN
United States
Post Number: 76
how are these comps speakers comparing them with infinity perfects. i wanted something which is bright but not harsh on female singer voices. would these focals do the job or should i look into another set.
Username: Jonathan_f
GA
Post Number: 3923
Not as harsh as Perfects, warmer, more balanced midbass, overall a warm and creamy sound with crisp treble.
Saint Paul, MN
United States
Post Number: 80
would u consider it an upgrade from perfects. also what other comp sets would have that sound that i'm looking for. i like CDT's but it seems their tweets are a bit too soft. i just cant think of a set off of my head.
GA
Post Number: 3925
I'd def consider it an upgrade from Perfects. If you thought the CDTs were soft and the Kappas a little too harsh, the Focal falls nicely in-between.
Home > Message Board > Car Audio > Speakers > Archive through May 25, 2005 > Hey Johnathan ??? on Focal Utopias [ « Previous ] [ Next » ]
