Home > Message Board > Car Audio > Speakers > Archive through May 25, 2005 > Jonathan or Glass, 240 ESOTAR??
Author Thread: Jonathan or Glass, 240 ESOTAR??
Username: Masse1369
Post Number: 23
I still haven't made up my mind yet on my system completely. From a simpler install stand point i think im going with a 2 way system. i was thinking maybe 240 ESOTAR? you seem like you like them a bunch. i listen to a lot of classic rock, 80's and 90's rock, older country. do you think these would be a good choice for me? i am going to use either the arc audio 2100-xxk or the zapco c2k2.0x2 for power. tell me what you think or if you would recommend something else. thank you.
Username: Masse1369
Post Number: 24
i wanted to let you know that i want to stick to the factory door locations of my 2004 yukon.
also, i plan on using an IDMAX12 or (2) idq12's for the subs. what would the difference be?
will an arc 2100-xxk power these? if not what amp would you run for these? thanks.
Username: Jonathan_f
GA
Post Number: 3922
In stock door locations I wouldn't recommend them, honestly, off axis in them is good, but not stellar. Kick panels would work better with that set (which is fantastic BTW, but dependant on install). CDTs are good off axis.
Home > Message Board > Car Audio > Speakers > Archive through May 25, 2005 > Jonathan or Glass, 240 ESOTAR?? [ « Previous ] [ Next » ]
