Home > Message Board > Car Audio > Speakers > Archive through May 25, 2005 > Good speakers for under 80 dollars?
Author Thread: Good speakers for under 80 dollars?
Username: Theceo
Post Number: 22
can anyone suggest any? i found these alpine sps570a on the circuit city website for 60 but everywheere else theyre bout 110, but the site was out of stock so i went to best buy to see if they had them n they did, but they said that since the website was out of stock that they would only meet me half way and take 30 off the price which would be about 80, should i take that deal? if not can someone suggest some good 5x7s/6x8s? thanks
Username: Transam396
Mcdonough, Ga
Usa
Post Number: 10
Hey chris for 5x7/6x8 u have a LOT of optionsI don't know how much ppls will like me mentioning other sites but u can try cardomain.com they have good prices and there is one called the zeb try google on that one will help you find the sites I'm putting the infinity 5x7's in my 04 F150 supercrew that i got off of ebay from tradingcity which is part of circuit city but they are sold asis i had to buy 3 pair to get 5 that worked just means that i have a spare I've got about 55.00 bucks invested in about 120-180 dollars worth of speakers
Home > Message Board > Car Audio > Speakers > Archive through May 25, 2005 > Good speakers for under 80 dollars? [ « Previous ] [ Next » ]
