Home > Message Board > Car Audio > Speakers > Archive through May 25, 2005 > Tweeter Mounting in Small Truck
Author Thread: Tweeter Mounting in Small Truck
Username: Solacedagony
New Jersey
US
Post Number: 411
Hey guys, I have a 2003 Ford Ranger, standard (not extended) cab. What would be the best position for mounting tweeters? Any concerns about tweeters in a small truck like that? Thanks for everyone's help in advance.
New Jersey
US
Post Number: 421
Anyone have any links, articles or information on tweeter placement?
Username: Jonathan_f
GA
Post Number: 3917
No pictures, but since you have a 6x8 up front, you could make a custom mount for the woofer and the tweeter and put them in the door together, usually tweeters will fit above the woofer in a 6x8 location, even if not, it won't take much trimming to make them fit.
New Jersey
US
Post Number: 426
So what you're saying is that putting the tweeters in the doors with the woofer will give me the best sound quality as opposed to mounting them elsewhere?
New Jersey
US
Post Number: 427
I am considering getting a set of CDT comps, btw.
GA
Post Number: 3929
It is almost always best to mount the tweeters close to the mid for optimum driver alignment (blending together). Only way tweets up top works very well is if you have the set crossed over in the 6khz region (rare) and you have a way to control volume level of the tweeters and time alignment.
New Jersey
US
Post Number: 429
Oh alright, thanks for the input, I'll have to make some kind of mount in my door for the woofer and the tweeter. Any specific material I should use to build the mount and any tips or trick you could think of off the top of your head? Thanks again Jonathan.
GA
Post Number: 3932
Wood if possible, be it plywood (marine grade is good) or MDF. Either way, if it isn't marine grade, try to seal it, stain it, whatever tickles your pickle to prevent the wood from water damage. Wood dampens resonance much better than metal and you'll get a cleaner sound. If you want to go a step further, sound deaden underneath it and sound deaden the entire door, closing off any holes that could allow the rear wave from the speaker to reach the front wave. This will minimize cancellation, tighten up the enclosure and give better sound with stronger midbass. No real tips or tricks, if you make the wood mount to fit the 6x8" hole and cut out for the woofer and tweet, you'll be good to go. Some minor trimming/cutting at the speaker opening may be required, nothing big or difficult, though.
Home > Message Board > Car Audio > Speakers > Archive through May 25, 2005 > Tweeter Mounting in Small Truck [ « Previous ] [ Next » ]
