Home > Message Board > Car Audio > Head Units > Archive through May 27, 2005 > Pioneer DEH-P4700MP vs. Pioneer DEH-P...
Author Thread: Pioneer DEH-P4700MP vs. Pioneer DEH-P6700MP
Username: Basketballinu05
Post Number: 61
alright i am going to buy 1 of these two HUs the DEH-P6700MP is 40 more i think or somethin so for the money besides a better display what advantages does it have over the lesser DEH-P4700MP in terms of sound quality and functionability i just have one 15 sub would the DEH-P4700MP get the job done?
Username: Illuminator
Post Number: 173
It would be the best if you went to www.pioneerelectronics.com and compared the two yourself...but from what I can tell, it looks like the only advantage over the screen is that the p6700 also has built in high and low-pass crossovers.
Post Number: 62
what is the high and low-pass crossovers used for and will i ever need them?
Post Number: 176
They are used to cut off frequencies below(high pass) or above(low pass) a certain level. You will only need them if you plan on hooking up a subwoofer and/or a component speaker set.
Post Number: 64
i have a sub but is it necessary or just somethin that would help but i wouldnt have to have it to run the subs
Post Number: 191
It would help...it would cut off higher frequencies that the sub isn't designed to handle, so you would get less distortion and you could turn it up louder.
Username: Csfan14
Panama City Beach, Fl
Usa
Post Number: 10
get the 6700 the high pass will help unless you lister to low music or are going to but all new speakers.
Home > Message Board > Car Audio > Head Units > Archive through May 27, 2005 > Pioneer DEH-P4700MP vs. Pioneer DEH-P... [ « Previous ] [ Next » ]
