Thread: 6x9's Alot better then 6/12?? |
New member Username: Alex_ochoa
Tucson,
AZ
Post Number: 1 Registered: May-05
| Posted on Wednesday, May 11, 2005 - 12:35 pm: |
I have a 98 altima and my rears are 6 1/2. I Want to buy the infinity kappas, but not sure which ones to get. I could easily cut out the 6x9 shape in the rears, but is it worth the time and little extra money? I know Kappas are one of the best speakers around and will be pushing speakers at there RMS. Thanks for your help. |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 544 Registered: Mar-05
| Posted on Thursday, May 12, 2005 - 03:01 am: |
Do you have subs? If you don't have subs and want to add a little bass the 6X9's will work, but if you have subs just front speakers will do nicely. However if you have subs and you want rear fill I would stick with the 6.5's |
Tucson,
AZ
Post Number: 3 Registered: May-05
| Posted on Thursday, May 12, 2005 - 05:39 pm: |
I have subs, but didn't know if 30 watts extra would be a big diffrence. i will just stick to my 6.5 Thanks for the help |
