Thread: Newbie needs help with car setup :S |
New member Username: Birdcr
Post Number: 4 Registered: May-05
| Posted on Tuesday, May 10, 2005 - 11:31 pm: |
Hi i have a rather pathetic 106 mardi gras, it currently has the standard cassette radio, i would like to upgrade my whole audio system, i have no alarm on this car therefore do not particually want to spend loads of $$$$$ on hardware, i think i should just relace the head unit and front speakers (13cm if im correct). i am open to opinions on a suitable setup and also would be happy to recieve advice on what items to purchase (head unit MUST have CD-r, CD-rw, RDS and MP3). is there any way of conecting a small sub under a passenger seat or somthing without needing a amp? I am confused about front speakers and tweeters in particular :S. any help would be deeply appriciated, Craig |
Silver Member Username: Erik123456
Post Number: 552 Registered: Aug-04
| Posted on Wednesday, May 11, 2005 - 12:10 am: |
where the heck do you live lol...13 cm in a mardi gras 106 either im really tired or you are from latvia or something  |
Silver Member Username: Illuminator
Post Number: 163 Registered: Apr-05
| Posted on Wednesday, May 11, 2005 - 01:50 am: |
That's what, 5 and 1/4 inches? You could do quite a bit with that...primarily buy a component set of speakers, Infinity would be a good way to go as Erik has mentioned before. For a headunit, check out Alpine, Clarion ProAudio, or Pioneer. You could get a pre-built, powered sub for under your seat. Check out Clarion's SRV303 and Infinity's BassLink. |
Post Number: 5 Registered: May-05
| Posted on Wednesday, May 11, 2005 - 08:18 am: |
i live in england mate, with the powered sub u recomend where do u recomend this to be installed in the car? is there any good budget powered subs, im a little short on cash as i am a student. |
Post Number: 164 Registered: Apr-05
| Posted on Wednesday, May 11, 2005 - 09:15 am: |
If you can fit it under the passenger seat like you were saying before, that would be a great spot. You can look for it used on Ebay and save a great deal of money compared to buying it new. |
Post Number: 7 Registered: May-05
| Posted on Wednesday, May 11, 2005 - 01:30 pm: |
do u have to fit it under the passenger seat? if so how do u? |
Post Number: 165 Registered: Apr-05
| Posted on Wednesday, May 11, 2005 - 05:17 pm: |
It doesn't have to be placed under the seat, but it will sound the best there. You just slide it under the seat with power and RCA cables hooked up. |
Post Number: 9 Registered: May-05
| Posted on Thursday, May 12, 2005 - 05:06 pm: |
does it need fixing to under the seat? any cheap recomendations? |
Post Number: 175 Registered: Apr-05
| Posted on Thursday, May 12, 2005 - 07:20 pm: |
You may try attaching velcro to the bottom of the unit if you have carpeting under the seat. |
Post Number: 10 Registered: May-05
| Posted on Sunday, May 15, 2005 - 06:56 pm: |
good thinkin, i dont think i can fit anything under my seat tho, so i think it will have to go in the boot, will a good car setup only have 6/9's in the parcel shelf? |
Post Number: 217 Registered: Apr-05
| Posted on Sunday, May 15, 2005 - 09:32 pm: |
You mean one pair of 6x9s in the rear? Nah, you want the front speakers also...If that's what you are asking, that is.
Bronze Member Username: Csfan14
Panama City Beach,
Fl
Usa
Post Number: 26 Registered: May-05
| Posted on Monday, May 16, 2005 - 12:22 am: |
yea get like some 6.5 in the front. |
Bronze Member Username: Birdcr
Post Number: 11 Registered: May-05
| Posted on Monday, May 16, 2005 - 10:20 am: |
k so new front speakers and 6x9's in the back and a sub needed |
