Thread: What do you think of this system |
Bronze Member Username: Safa19
Post Number: 16 Registered: Apr-05
| Posted on Friday, May 06, 2005 - 10:38 pm: |
i already have an audiobahn a8002t amp and 2 12 inch audiobahn subs. im looking to get then infinity kappa 63.5i (6 1/2 inch) for the front and the infinity kappa 693.5i (6x9) for the rear and then hook up an audiobahn a6004t amp(75wx4). does this sound like or good set up or should i get a different amp? |
Bronze Member Username: Skyliner17
Saint Paul,
MN
United States
Post Number: 33 Registered: Apr-05
| Posted on Friday, May 06, 2005 - 11:11 pm: |
sounds good if u like audiobahn. |
Post Number: 17 Registered: Apr-05
| Posted on Sunday, May 08, 2005 - 09:37 pm: |
what would you suggest instead of audiobahn? |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 408 Registered: Oct-04
| Posted on Tuesday, May 10, 2005 - 12:25 pm: |
Depends what type of sound you are going for and how much you want to spend on it. (As always.) |
Silver Member Username: Loc_out
Post Number: 144 Registered: Feb-05
| Posted on Tuesday, May 10, 2005 - 01:25 pm: |
I would not go with audiobahn! Look for PPI Amp's |
Silver Member Username: Kklagge
Post Number: 131 Registered: Dec-04
| Posted on Wednesday, May 11, 2005 - 07:34 am: |
Joe...there is nothing wrong with that Audiobahn amp (A6004T)....I installed one in my wife's Xterra 2 years ago and it's still performing like a champ!! I personally would stay clear of their speakers though. |
