Home > Message Board > Car Audio > Head Units > Archive through May 27, 2005 > Dose any one know how to turn off the...
Author Thread: Dose any one know how to turn off the beep...
Username: Csfan14
Panama City Beach, Fl
Usa
Dose any one know how to turn off the beep on a pioneer radio????
Username: Illuminator
Post Number: 133
I'm almost positive that it can't be done without modifying the unit internally.
Username: Csfan14
Usa
My frind got his to turn off but his battery went dead. He has had it for years and now he frogot how to do it agin.
Username: Minime
Portland, OR
Post Number: 40
what model is it?
Username: Taylor17
Kopperl, Texas
Post Number: 1778
Sorry to change the topic a little, but that would be a cool trick. I have the Pioneer Premeer DEH-P640 if you know any cool stuff I can do to it.
Username: Algirard1
OH
United States
Post Number: 114
You hold the source button until the unit turns off and then hold the function button. Then there is a menu you can go through to change the clock and turn the beeping on and off.
Username: Taylor17
Kopperl, Texas
Post Number: 1786
cool, correction I have the DEH-P660 not the P640.
Username: Csfan14
Usa
I Have the Pioneer Premier DEH-P670MP i went in to the functions and there is no turn off beep on it.
Username: Csfan14
Usa
I just got two audiobahn Q-subs for $120.00 On this website i found www.millionbuy.com and i just got all new speakers and the hu and sub and amp for only $500. They all sound great to ghter but the f***ING BEEP WONT TURN OFF!!!!!!!
Username: Lilcharles22
Florence , Alabama
US
same here too
Post Number: 180
I'm sure you can take out the internal speaker that makes the hideous sound.
milhouse
Alan Girard is correct. You have to turn off your deck and hold down the function button. It's part of the DFS Alarm. Atleast that's what I think it's called. Trust me, it's in there. I just got an ampl installed and they reset my radio. I had to go in and turn it off again.
Post Number: 187
It is too bad it does not work for all models...
Username: Minime
Portland, OR
Post Number: 41
The 670MP doesn't have DFS alarm, so the only beep I can think of that he might be talking about is the warning tone when you turn the car off. If that's it all you have to do to turn it off is hold down the source button until the unit turns off, then hold down the function button until you see the clock, then press function until you see the word "Warning", and press up or down to turn it off.
Username: Minime
Portland, OR
Post Number: 42
If that doesn't make sense here's the manual:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/192089347DEHP67 0MPOperationManual.pdf
It's on page 41.
Home > Message Board > Car Audio > Head Units > Archive through May 27, 2005 > Dose any one know how to turn off the... [ « Previous ] [ Next » ]
