Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Alpine
Author Thread: Alpine
Username: Nz24
Post Number: 22
Is there any advantage to getting an Alpine head unit if you are hooking it up to an Alpine MRV545 amp. Right now I am Planning on getting the Alpine 9855. The salesman claims there is an advantage. Where I'm buying it sells Pioneer and Clarion as well. Any thoughts. Thanks
Username: Illuminator
Post Number: 131
The headunit itself has an amplifier link that controls some aspect of the V12 series amps. Other than that, I can't think of any reason why you would have an advantage to having the same brand amp as your headunit.
Username: Nz24
Post Number: 23
Thanks.
Username: Fishy
Tamarac Ft.Laud, FL
Post Number: 1054
Yeah, I think you can monitor amplifier temperature and supply voltage from the h/u with that link dealie.
-Fishy
Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Alpine [ « Previous ] [ Next » ]
