Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through April 16, 2004 > GLASS WOLF,TBONE need your HELP fast!...
Author Thread: GLASS WOLF,TBONE need your HELP fast! THANKS!
Username: Virulentv
hey,i am about to buy the following equipment. with no experience on my back for car audios i want to know if these components will match each other or will i be making a mistake ?!?
Headunit : Kenwood KDC-mp222(200W max, 22.5x4RMS)
Speaker pair: Pioneer TS-A6980R 6x9" 4-way(350MAX)
1 AMP: LEGACY LA490(600 Watt bridged or 300 watts x 2 with built in crossover )
2 SUBS: LWF12 (12" 250RMS each)
1 BANDPASS BOX: Dual 12" with Plexi-View Panel
10 disc SANYO CD CHANGER
plz help me out i am stuck here !! also will i need a converter or capacitor when i install the equipment?
thanks a lot !
Username: Tbone
Post Number: 35
Umair, answered your question under amplifiers, let me know your response there, then we can move forward. the Convertoer or Capacitor will probably not be needed running only one amp, but will depend on if your lights dim, Etc. will see about it then, but if you have the money, it can't hurt.
a concerned guy
quit, umair!! throw all of that shi t away!!! dont make a huge mistake and install that garbage into your car!! trust me, you will thank me when you dont. get only Jl audio, alpine, eclipse, or kicker
Username: Tbone
Post Number: 53
Umair, I e-mailed you a link to look at, as a concerned guy said "throw it away" is exactly what I told you, however, with your budget, a simple system of good components is not unrealistic, check the site I sent, and let me know.
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through April 16, 2004 > GLASS WOLF,TBONE need your HELP fast!... [ « Previous ] [ Next » ]
