Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > VDO RB3-00 22rc260/65s
Author Thread: VDO RB3-00 22rc260/65s
Username: Waruna
I got a VDO RB3-00 22rc260/65s head set without display unit.
http://car.depenet.com/?product=2265
Can I use this in a car other than peugeot?
Username: Illuminator
Post Number: 129
Probably...unless there is a very specific plug on the back of the unit, you should just be able to cut and strip the wires and match them up to the harness of a different car. Going with an aftermarket headunit would be a better idea, though.
Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > VDO RB3-00 22rc260/65s [ « Previous ] [ Next » ]
