Thread: Man wassup with Alpine Headunits??? |
New member Username: Black013
Post Number: 5 Registered: Apr-05
| Posted on Thursday, April 28, 2005 - 02:02 am: |
My Premier deh 960 pioneer is in the shop so I decided to throw in my brother alpine cda 9811 but is it me or does alpine cd player produce less bass or am I just spoiled by my pioneer cd player?also do anyone know does this headunit have preset eq like superbass,vocal because I get tired of messing with bass and treble? |
Silver Member Username: Illuminator
Post Number: 128 Registered: Apr-05
| Posted on Thursday, April 28, 2005 - 02:12 am: |
Doesn't it have some type of Bass Engine feature? |
Bronze Member Username: Adampit
Post Number: 46 Registered: Dec-04
| Posted on Thursday, April 28, 2005 - 07:17 pm: |
Ya know, i agree with you daryl, i am seriously thinking about selling my alpine 9835 and going with something else because of the lack of bass it produces, i find the same as you. |
Gold Member Username: Fishy
Tamarac Ft.Laud,
FL
Post Number: 1041 Registered: Sep-04
| Posted on Friday, April 29, 2005 - 07:01 am: |
Lol, maybe Alpines just have a flatter frequency response. Regardless, I get plenty of bass out of my 7831. -Fishy |
Post Number: 6 Registered: Apr-05
| Posted on Friday, April 29, 2005 - 10:09 am: |
yes it seems my highs are louder bus my bass is gone or at least flooded by my highs |
Gold Member Username: Carguy
Post Number: 2694 Registered: Nov-04
| Posted on Friday, April 29, 2005 - 10:54 am: |
Daryl, sometimes a cheaper HU will give you more bass. What is deceiving about that is, the bass you get isn't always what's in the music. Sometimes it's called distortion. What some units do is, take a small part of a sound wave, and amplify it many times. It may sound good sometimes, especially if it mixes well with the background music. However, that in a scope might show a distorted wave. The point I'm trying to make is, the loud bass you hear isn't always real. From my experience, rap or any songs with heavy bass will sound reasonably good. But in that same environment, if you played a classical cd, you'd see how much of the bass/music was being distorted. In classical, if you over amplify certain part of sound frequency, it'll sound terrible. |
NorthWest,
Michigan
Post Number: 7801 Registered: Dec-03
| Posted on Friday, April 29, 2005 - 01:43 pm: |
the default "flat" setting for the sub pouts on the 9811 are less than 4V. turn the sub out level up to about +5 and you'll be at a 4V output and it should sound normal.
Post Number: 47 Registered: Dec-04
| Posted on Friday, April 29, 2005 - 07:26 pm: |
Glass, any opinins on getting more bass out of my 9835? |
NorthWest,
Michigan
Post Number: 7809 Registered: Dec-03
| Posted on Friday, April 29, 2005 - 11:24 pm: |
max out the sub level setting. set XO to 80Hz, if you can set slope, sset it to 18dB see how it sounds
Tamarac Ft.Laud,
FL
Post Number: 1050 Registered: Sep-04
| Posted on Friday, April 29, 2005 - 11:55 pm: |
the default "flat" setting for the sub pouts on the 9811 are less than 4V. Yeah, that makes sense. My 7831 doesn't have sub outs and I'm using an 8v max PPI frx-456 anyways. -Fishy |
