Thread: Kenwood CD Unlock Code |
| Posted on Wednesday, April 27, 2005 - 11:12 pm: |
KENWOOD SECURITY CODE CLEAR procedure These codes are applicable for all Kenwood radios that do not have DVD or DVD screens located on unit. Your radio will require one of the following procedures. Type 1 During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears). Then using your remote enter your code. Type 2 Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear". Then using your remote enter your code. Type 3 Model# DPX-4020 and DPX-4030 Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display. Then using your remote, enter your code. Enter your number from the remote control unit. Your code number is 5227 (KCAR) * Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key on the remote * Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key on the remote * Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key on the remote * Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key on the remote The security is canceled and the set enters the TUNER mode! |
| Posted on Sunday, May 01, 2005 - 09:26 pm: |
We recently purchased Kenwood KDC-202MR at flea market and receiver seems to work but not CD, is there a security code on CD for this unit?There is no remote or paperwork with the unit. |
Unregistered guest |
| Posted on Monday, May 16, 2005 - 01:12 am: |
i recently bought a kenwood KDC- 516 at a garage sale and it does work but it says you need to enter your code. But when we bought it we didn't have any paperwork or remote. How can I get the code?
Silver Member Username: Illuminator
Post Number: 219 Registered: Apr-05
| Posted on Monday, May 16, 2005 - 01:33 am: |
You must have the remote to attempt to unlock it. |
| Posted on Sunday, June 05, 2005 - 11:16 pm: |
HOW CAN I GET MY CODE NUMBER I GOT KENWOOD kdc-322. |
Post Number: 459 Registered: Apr-05
| Posted on Sunday, June 05, 2005 - 11:19 pm: |
Call Kenwood or an authorized service center... |
| Posted on Tuesday, June 14, 2005 - 04:08 am: |
Hi there does this work for the Kenwood DPX-990MD model. I think it's a Japanese model? Also does this enable the Cd features. Please reply to guesshuiam@hotmail.com |
