Thread: Help with Sony car radio |
| Posted on Wednesday, April 27, 2005 - 06:17 am: |
I got a SonyCDX-L450 cd front loader but i dont have the wiring diagram for it,any help? |
Silver Member Username: Illuminator
Post Number: 127 Registered: Apr-05
| Posted on Wednesday, April 27, 2005 - 06:12 pm: |
Nearly all aftermarket stereos use this color code. The only wire missing from the diagram is the blue one with the white stripe which is the amp remote turn on wire. From http://www.bcae1.com/ |
New member Username: Rlitch
Walsall,
West Midlands
United Kingdom
Post Number: 1 Registered: May-05
| Posted on Tuesday, May 10, 2005 - 06:39 am: |
The lights gone out on my display on my Sony Car Radio - where do I go? Please and thank you |
Post Number: 158 Registered: Apr-05
| Posted on Tuesday, May 10, 2005 - 05:34 pm: |
Take it to a factory authorized repair center.But if you have a warranty, you might want to call the number listed on your warranty card first so they can tell you what to do with the unit. I hope that helped somewhat... |
