Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Pioneer vs. panasonic??? 4 volts vs. ...
Author Thread: Pioneer vs. panasonic??? 4 volts vs. 6.4 volts?
Username: Hellbender
Los Angeles, California
Post Number: 32
I was thinking of upgrading to the pioneer deh-p860mp ,deh-8600 or the panny cq-cb8901u with the HD tuner. Which one do you guys think is better? The 860 has 6.4 volt preouts and the p8600 has 4 volts, is that a huge difference? If its not then I would elimiate the p860 from the equation since the p8600 is identical in every other way at a cheaper cost. Thanks
Username: Illuminator
Post Number: 121
I think the extra 30 or so dollars is worth it to get the Premier label on the unit which usually equates to better durability than the regular. And, personally, I would go with the Panasonic if you used the Tuner and Aux input the most. If you usually listen to CD's, you'd be best off with the Pioneer.
Post Number: 33
Thanks for the input Jexxen, Anyone else have any opinions?
Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Pioneer vs. panasonic??? 4 volts vs. ... [ « Previous ] [ Next » ]
