Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Panasonic deck
Author Thread: Panasonic deck
Username: Shea88
Cartwright, Manitoba
Post Number: 15
Hey there, I have a panasonic cq-c5310u, (plays mp3 wma etc) I bought the deck last August, when i first got the deck I would burn cd's with 200 songs and the deck would load them weithin 20 seconds of being turned on. Now 8 months later I have found that I can put a cd with 160 songs in it and somtiems it will load in 10 seconds and other times it will take several minuetes to load the cd even if its completely clean. Does anyone know why?
Username: Baumer8907
Maye if the deck has mp3 memory in it the amount of songs has grown to great for the deck to handle
kinda like if u install to much stuff on ur computer it starts running slower
Username: Illuminator
Post Number: 116
It only does that with mp3 format CD's?
Username: Shea88
Post Number: 16
it does it with only mp3/wma cd's
Username: Kd7nfr
Montpelier, ID
United States
Post Number: 8
Try reseting it. It's usually a small button on the face of the deck. Push it with something, I usually us a paper clip. If that doesn't work, try playing a cleaning cd in it.
Username: Sheldon
hi guys i have a jvc cd deck 180w and i have 2 180w 4ohms speakers but the speakers sound disstorted at high volumes. if i hook them up in parrell can i cause damage p.s. no amp
Username: Disturbedpriest
Post Number: 93
whats the watts rms on those speakers??? i would get a lil amp just to take the pressure off your jvc.
Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Panasonic deck [ « Previous ] [ Next » ]
