Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Radio=amp is on..cd=amp turns off??pl...
Author Thread: Radio=amp is on..cd=amp turns off??please help
Username: Vwgn
Post Number: 12
when i turn on my car and hu everything works fine amp,sub,..when i put in a cd the amp turns off? wtf is going on?...also when i leave my face on the hu and turn the car off then on it has memory when i take the face off all settings and mem r gone and if i have a cd in there it says cd eject? any help would be great...thanks
Username: Subfanatic
Walton, Ky
Post Number: 2834
ur remote wire is on the wrong other wrie
Username: Vwgn
Post Number: 13
? i have a blue one and a blue w/white stripe it is on the blue one is this what you mean? and does that have anything to do with the hu memory issues? or just the amp?...thanks
Walton, Ky
Post Number: 2856
amp
Username: Vwgn
Post Number: 14
amp? is the problem? i dont get it could you please explain
Walton, Ky
Post Number: 2871
the solid blue one is the one it should be
Username: Glasswolf
NorthWest, Michigan
Post Number: 7742
use the REM wire, not the PWR ANT wire on the head unit.
Username: Vwgn
Post Number: 15
the solid blue one is the right one? i have it hooked up to the solid blue one...?
Walton, Ky
Post Number: 2888
glass, usually when i hook up amps for epople i do use the REM wire, but for some reason in my car the only that works is the PWR ANT wire, why is this?
Username: Illuminator
Post Number: 113
The amp turn-on lead is the blue one with the white stripe, not the solid blue one.
Username: Glasswolf
NorthWest, Michigan
Post Number: 7744
sub, you have both a rem and pwr ant? or just pwr ant?
Username: Kd7nfr
Montpelier, ID
United States
Post Number: 7
I usually run from the remote wire on the deck, to a fuse, to a switch on the dash, to the amp...
Reason I put a fuse, is one time I had a nice SoundStorm deck blow up on me because it meet ground...
Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Radio=amp is on..cd=amp turns off??pl... [ « Previous ] [ Next » ]
