Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Bad Memory Wire
Author Thread: Bad Memory Wire
Username: Black013
My memory wire bad on my harnees in a 83 custlass brougham be cause eveytime i cut the car off and cut back on the clock says 12:00 and my settings are erased I was wondering how can make my own memory wire can I run remote wire from the batter or something?
Username: Illuminator
Post Number: 111
Yeah, you can run new wire from the battery, but you might want to use a somewhat thicker gauge wire than remote wire.
Home > Message Board > Car Audio > Head Units > Archive through May 04, 2005 > Bad Memory Wire [ « Previous ] [ Next » ]
