Thread: Preamp outputs |
New member Username: Dfresh
Post Number: 7 Registered: Apr-05
| Posted on Saturday, April 23, 2005 - 09:02 pm: |
I'm a little confused about preamp outputs. When you connect an amp to a preamp output, does the bass/treble levels on the head unit affect the signal going out of the preamp outputs? For example, if I change the bass does that affect the bass level being sent to the amp for the subs? I'd appreciate it someone could clarify this for me. Thanks |
Silver Member Username: Illuminator
Post Number: 107 Registered: Apr-05
| Posted on Sunday, April 24, 2005 - 11:27 am: |
Yes, the tone settings on the headunit affect the signal going to the amplifier. |
New member Username: Kd7nfr
Montpelier,
ID
United States
Post Number: 9 Registered: Apr-05
| Posted on Monday, April 25, 2005 - 11:03 pm: |
It depends on the deck. High-end decks usually have an equilzer/crossover or both for the subwoofer channels, or preamp channels. Then they have a level adjuster so you can adjust the amp level to the specific type of music. |
Bronze Member Username: Msully701
Stratford,
Connecticut
US
Post Number: 67 Registered: Apr-05
| Posted on Tuesday, April 26, 2005 - 05:38 pm: |
so would it be best to turn everything to 0 on the amp and just adjust it by the HU? |
